Hi All
I have a Range Powermaz 155x installed at home and I am having some problems with the central heating. Recently I have found that the pressure is dropping (indicated on the front panel) when the heating is off (the burner is off). I am regularly refilling the system to take it up to the 1bar point. When I say regularly I mean daily or less! Once refilled the burner comes on and the pressure steadily rises to 2.5 bar or there abouts. Once the burner goes off the pressure drops over a short period (approximately an hour or so) down to near 0bar, which can eventually lock the system... I then have to repeat the process so I can get some heat in the house... Now I have looked through some of this forum and the general consencus from people who have faced the same problem seems to be that there is a problem with the expansion vessel.
Now for my question.... If that is the case, which expansion vessel are we talking about? There is the dhw expansion vessel in the unit and also a Zilmet external 18l expansion vessel... Which one is likely to be causing me a problem? How can I check to see if the expansion vessel (which ever one it is) is truly knackered, and if so, where would I go to get a replacement.
I don't really want to call out a heating engineer unless I really have to. Money is a little tight at the minute.
Any help or guidance would be gratefully appreciated.
