tldr: What type/spec cable would be ran from the solar inverter panel in the loft to the consumer unit?
The longer version:
Going to get the keys to my first house in the next 2 weeks - finally getting free of the rent trap! We are planning a light refurb involving changing a few things around in the kitchen, running data cables throughout the house, installing av cables in the walls of the lounge followed by a full repaint and new flooring throughout.
Eventually I was hoping to get solar panels installed (not enough in the budget to get them straight away). Due to a double story extension the consumer unit is in a cupboard dead centre of the downstairs floorplan. I figured whilst going through initial upheaval now I could put whatever cabling in place that is required to run from the loft as it would save a lot of redecorating or lifting floors in the future. What type and spec of cable is ran from an inverter to the consumer unit, does it require metal or plastic conduit and would sparkys be happy to use an unterminated cable thats been pre fed through by the homeowner? My plan would just be to leave a few metres coiled up at each end to give a future installer enough to work with.
The longer version:
