After 6 years since new the system (Premier 24) started reporting a battery fault. As per discussions on this forum I went for a new battery (same spec etc). Plugged it in but the panel still flashes up Battery Fault.
Question is: will it reset after 24 hours (or whatever the test cycle is set to) or do I need an engineer to reset it?
I do not have an engineer's code because the company that installed it won't give it to me. Not that I am under a service contract or anything, I never will, not with them anyway.
Thanks in advance.
Thanks in advance.
