I know there has been a lot of discussion around these in the past from doing a few searches...
However, mine used to be fairly reliable and I turned off the signally a while ago for arming/ disarming etc as it was no longer necessary. Having turned it back on via Wintex (which works perfectly) I can no longer get sms notifications.
I have however changed from EE as TalkTalk as my provider?! Could this be the problem?
I've also read about OpenTap today and wonder if that may assist.
I *think*, but need to check I am using the center numbers: 07785 499993 and 07860 980480.
Does it matter which order these are in? I understand the 02 one is unreliable.
The wintex is giving the error message of comms failure, or something similar so it is trying to send.... but I am not sure why the messages are not coming through.
What 2 numbers should I be using here?
Help appreciated - thank you.
