- Joined
- 19 Dec 2019
- Messages
- 14
- Reaction score
- 1
- Country
Morning,
I'm building a hearth for a log burner. Plan is to use bricks to build it up from the concrete subfloor. I need to level before tiling. Can I shutter it and pour a thin (say 5mm) layer of self levelling screed to give me a flat surface to tile from?
My concern is heating might cause cracking / expansion.
Is a concrete (hardibacker) board better? If so how would you attached to the brick hearth below?
This is only for the base - the sides I'm using concrete backer boards as obviously a screed is not an option.
Second question - is there an issue with small air gaps being left between the tile and adhesive layer expanding? It's not exposed to direct heat but I imagine it'll get quite hot.
Thanks in advance!
Thanks in advance!
