- Joined
- 15 Aug 2005
- Messages
- 1,630
- Reaction score
- 6
- Country
Prior to me removing the existing tiles in the bathroom some had worked loose and some had actually fallen off. I suspected this was because the tiler had only put five "blobs" of adhesive on the back of each tile.
Anyway, I was going to put up decorative cladding so I screwed some battens to the wall with Gripfill (green tube) added for good measure.
Cue, she who must be obeyed deciding that she now wants tiles. So today I removed the battens. I was expecting some resistance from the Gripfill, but the battens came off easily. There appeared to be no adhesion by the Gripfill to the plastered surface below. Bearing in mind that I now intend to fit 300 x 400mm ceramic tiles to these walls should I consider some sort of primer or other preparation before I proceed. Any advice greatly appreciated.
