Hi Guys
I'm about to lay granite tiles on top of 22mm wooden floors and have a few queries about how to prep. Basically, I want to get things right to avoid problems long term.
1. Should I seal the tiles prior to laying - I was thinking especially the edges to prevent grout dye soaking in from the edge of the tiles
2. What is the minimum thickness of exterior grade plywood I should use. The actual subfloors are flat and true
3. Do I need to seal the plywood with PVA prior to laying the tiles. I'm using flexible adhesive, given the wooden floors.
While I'm on, I also have a shower cubicle to tile. Presumably I should be tanking the walls prior to tiling. Can anyone recommend a simple to use and effective tanking product?
Many thanks in advance
