Preparation for Thermalite blockwork?
27 Oct 2018
I was chatting with a mate who retired from plastering 20 years ago, he reckons a really weak mix of PVA is required to limit suction.
Trouble is he didn't say how weak or how many coats? He did say hit it with a 2nd stronger mix but didn't say how strong! Read horror stories on the forum about PVA peeling off! I would like to avoid any plaster ending up on the floor ideally!
Also, how soon do you put the undercoat on after PVA'ing?
This is probably a can of worms questions but would you use Dricoat or Hardwall for thermalite.
I did think of lathing the whole wall with expamet but it's a big area, in a kitchen and I suppose liable to rusting eventually if I don't use stainless steel lath.
By the way, it definitely Thermalite and I'm not just bandying the term about generically. It's as soft as baby's sh............. and as horrible as. :)
If it was me I’d pva it as it’s going to be a pig of a job, but strictly speaking you’re meant to just soak them.
I’d use hardwall = high suction backgrounds.
Doubt there’s any need to wait for pva to dry, it’ll be dry before you’ve finished coating it.
Thank god for dot and dab...
Mines all covered with insulated plasterboard glued straight to block work and skimmed .
