- Joined
- 6 Sep 2004
- Messages
- 1,069
- Reaction score
- 71
- Country
I have replaced a low level WC with a close-coupled WC and now wish to tile the wall behind the WC cistern area. The wall is made from 18mm plyboard and covered with a reasonably thick paper. I have some questions that I would appreciate some advice on?
1) What is the best way to remove the paper from the plyboard? I imagine that it would be unwise to use a heat gun as it would be likely to cause the wood to swell? Should I dampen the paper? Or could I use a sander?
2) Once the paper is removed what steps do I need to take to prepare the plyboard for tiling? Is it necessary to use PVA for what should be a dry area?
3) In order that I could get access to run a new water supply pipe at a lower level to the WC I have had to cut a hole in the plyboard of approximately 9 inches square. Can I supply a 9mm plyboard panel to fit this hole or should it be 18mm? If I can, is it possible to glue it into place using Gripfill whilst being held by a couple of batons until the glue is set?
Thanks very much for any help.
