Preparing shiny walls for plastering
4 Dec 2003
The walls have a shiny paint on them, donkey's years old. Should I remove all the paint or can it just be pva'd and plastered over? It seems fairly well adhered to the wall but comes off easily with a scraper. Still a good few hours to get it off though. Not sure whether it's gloss or shiny emulsion, probably the latter.
Cheers
JD
I'd scrape off what you can then PVA it.
joe
Do you think I should score the paint where I can't remove it? Some is obscured behind a water tank.
Cheers
JD
No. As long as it's basically stable just PVA and plaster (assuming that you can plaster).
joe
No that's one thing I can't do! I have a plasterer lined up but can't get hold of him right now and want to get the work done today.
What I don't understand is that as the paint is shiny how does the pva adhere to it? Maybe I should sand the paint first?
Thanks again.
JD
sand it with coarse Aluminium Oxide paper ;) then 2 coats PVA diluted as per instructions on tub.......then final PVA by plasterer befor he skims it
sand it with coarse Aluminium Oxide paper icon_wink.gif then 2 coats PVA diluted as per instructions on tub.......then final PVA by plasterer befor he skims it
Right, wiill do.
Many thanks to you both, dunno what I'd do without this forum.
JD
