Preparing tiled floor for over laying with vinyl
30 Sep 2013
Lanarkshire
Hi all
I'm planning on sprucing up my bathroom a little, part of this will be overlaying the tiled floor with vinyl. As part of this I want to fill in the gaps between tiles to give a level surface. I posted on here before about how is the best way to do this. The replying had was self leveling compound. Unfortunately I'm not overly confident in doing this, I'd prefer to use some sort of filler which I can then sand down. Is there any particular type that would be suitable for this or anything else which might be suitable?
Cheers
Hi all
Cheers
Get a professional to level the floor. Will be a better finish that sanding down filler.
Have used car body filler (2 part) just mix enough for what you can use and use it quickly ! it sets in minutes,try to get it in the groves neatly first time so to avoid sanding,sanding is a pain as it sets rock hard.
Could buy the cheap body filler as its not going to be seen.
Finished result was excellent with no grin through the cheap thin vinyl.
Good luck.
I advised you previously (last june?) & no mention was made about SLC?
Sorry mmcgar. I've just realised what you meant! Ignore my suggest
Vinn I'm still waiting for you to reply to me. I need help on my floor screed issue. How would you sort it out?
