I've been filling a wall that has had wallpaper removed from a previously emulsioned wall. It was in a bad way and has required lots of filler. My questions are as follows;
1/ After rubbing down, the filled surfaces remain dusty, if you drag a finger across it comes away white. Is this normal ? I've noticed in that washing the wall after filling can wash the filler away. What is he best approach to cleaning up before painting ?
2/ What should my first coat be on a wall that has been filled ? A mist coat, an oil based primer ( thinned ? ) or something like Zinsser BIN ?
Thanks in advance
Thanks in advance
