Preserving T&G Glued Hardwood Floor - Is it possible?
17 Nov 2016
I'm new to flooring so bear with me. I have started a T&G hardwood floor. I'm floating over floorboards but gluing the boards together. Started the first 3 rows but have noticed gaps in the boards where some of the boards are not the same width therefore giving me gaps where they overlap on the next row. Is there anyway I can easily lift and preserve some of the boards and slot in better matched boards therefore not giving me any gaps.
Some way of cancelling the glue affects?
Thinking about just letting it go but suspect I'll have further gaps if I progress as I am.
Please advise
Chris
Why have you chosen this method?
What condition are the sub-floor boards in?
What material/brand name are you using?
Are you examining the boards before laying them?
Did you try loose laying a few rows to a set line?
Its possible to cramp up the boards - but are you going up to skirting spacers (10mm to 15mm) or going under the skirting?
Vinn hi,
Because I didn't want to ruin subfloor. Also seemed easiest. It has been laid previously with no fixing but it does move so I need to relay to fix it. I don't want to nail.
Good.
Wickes. Oak.
Yes but my eyes are getting bad!
Yes. That all worked ok. Think my kids got in before the boards had time to glue together properly.
Going under.
I need to know if easy way to lift or if there isn't without destroying boards.
Read more: //www.diynot.com/diy/threads/p...od-floor-is-it-possible.471128/#ixzz4QIekbhEB
If I understand - the situation is that you have a T&G subfloor that you dont want to nail into, hence this type of Wickes Oak flooring.
The Oak boards are being glued together?
You've not mentioned any underlay?
To remove any boards you will typically have to lift from the last board laid & keep lifting until you remove the defective board.
Clean off the glue before re-laying
Suction clamps used for lifting glass or large tiles will help, or perhaps even lift a glued board but they would be an added expense. google them.
