I am planning to have a 250L unvented system installed. From another thread have come to the conclusion that most of the main unvented systems have similar performance. Having read various other threads it is clear that pressure and flow are important. My situation is as follows:-
1) existing cold water supply pipes are 15mm
2) pressure at first tap in the chain is approx 4 bar
3) flow measured at 30 litres per minute based on 3 open taps
4) unit will be approx 5 metres above tap where pressure was measured
5) shower mixers are Bristan Java thermostatic
6) currently two showers are run from a pumped (at 1 bar I think) gravity supply and give acceptable performance
7) however bath fill from the unpumped 3 metre head is lousy (Marflow Tangent taps which look great, supposedly operate at low pressure, but I suspect are only suitable for mains pressure)
I am planning to add a further ensuite shower hence the need to change system - unlikely that all three be be used at the same time.
I can see that these figures are marginal but is anyone prepared to share experience about the likely end result. In terms of making it better would a 22mm direct supply to the unit make a significant difference.
The builder will choose the plumber - hence wanting to double check as much a possible before installation starts.
