I have a gas bottle fed water heater on the balcony.This supplies 5 lt/min.
The pressure into and out of the heater is 25 psi and only supplies a kitchen tap and a shower,but it is very slow.The heater is clean inside and valves open OK. When the weather is bearable outside I hope to install a Ariston F1 heater which will up the flow to 11 lt. I hope to resite the pipes to stop the cold feed freezing up. I want to go straight down through the balcony floor to the kitchen below which is about a 3 metre drop.At present the hot goes up one metre,across the walkway and down to the kitchen.But by going straight down I now lose a metre of gravity pressure but is this balanced by the need to raise it a metre.? Will it be more , less, or the same. The water is from a mountain well, not pumped just gravity. It goes through 3/8 pipe with smallbore flexible couplings. I hope to change the 3/8 to 1/2" Sorry it sounds like a school exam, but it is going to be a lot of work and I dont want it to be a waste of time. Thanks for any ideas.
