I wish remove the airing cupboard and have a better shower so a high flow combi ( 2 bathrooms and 5 adults). Taking advice from the forum I had 3 plumbers including the gas board for a quote. No used a pressure gauge and visually checked the flow from the kitchen tap and said not enough pressure.
I have a new 25mm mpde supply to the house with 2m of 15mm before the 15mm stop valve. The stop tap in the pavement and inlet the the house are fully open. At the kitchen tap I have 12 l/m. With a gauge on the garden tap, 2 m from the house stop valve I get 20m+. With the kitchen tap fully on I still get 6m at the gauge..
The gives some questions.
As the kitchen tap is a mono bloc mixer is the flow restricted (.6 bar back pressure )so gives a bad indication of flow avaiable?
Does the 15mm stop tap limit the supply to the house?
If I reduce down from the 25mm MDPE to 22mm with a 22mm stop valve and 22mm to the boiler what flow can I expect .
Thanks for reading the message
