I have a solar water system (closed) with a pressure gauge.
The gauge keeps failing (replaced once under warentee).
The gauge reading fluctuates with temperature quite widely now (0.2bar @ 8 degrees centigrade to +1 bar @ 38degrees centigrade and higher).
I have attached a calibrated test gauge which reads a fairly constant pressure (1bar to 1.1bar) under the above conditions.
I suspect the gauge has failed when the water temperature has exceeded it's max' temp.
What are the most reliable pressure gauge manufactures with a high working temperature?
