So i had a go at replacing a radiator.
old one came off fine, checked boiler pressure and the needle hadn't moved, but why would it.
inhibitor went in the new empty rad ok, bleed valve open, lockshield? valve open and away we went.
had a helper watching the pressure and it didn't move.
radiator stopped filling though so obviously no pressure in the system.
its a worchester combi greenstar 30cdi boiler with a plastic filling key so i let some more water in hoping the needle might be persuaded to move in the other direction but it still didn't move.
so, is there any way i can re-pressurize the system myself for tomorrow? can i fit a second pressure gauge into a radiator bleed valve or something until the boiler valve is replaced? will that work?
i'm not keen on turning the boiler on at all because the pump runs every 24h to prevent seizing which i'm sure would not go down well if there is no pressure in the system, is that right?
thanks.
thanks.
