This combi is losing a bar of pressure every couple of hours but no sign of any leaky rads/pipes. Water does leak from a pipe leading down from the expansion tank to the Giannini hydraulic valve, a pint at a time, very suddenly once a week or so when its in regular use. This seems to have stopped since we've been using the CH less. This pipe was twisted by a plumber trying to tighten a leaking joint, but the pressure drop started months after this. The boiler works fine as long as its regularly pressured up.
Could the hydraulic valve be damaged as a result of the twisted pipe? Would this account for the pressure drop? I've got a CORGI plumber coming in to look at it this week, but would welcome any advice. I'm hoping its not going to be new boiler time.
