PRESSURE LOSS
17 Jun 2007
Middlesbrough
WORCESTOR BOSH 240 DRAINED SYSTEM DOWN TO ALTER SOME PIPEWORK FOR MOVING RADIATOR.WHEN I RECHARGED SYSTEM AND BLED ALL RADIATORS WITHIN HALF AN HOUR ALL PRESSURE IS GONE AND THERES NO VISIBLE LEEKS ALSO BOILER TRIPS OUT,TRYED RECHARGING HALF A DOZEN TIMES STILL DROPS
must be a leak / loose joint you havent thought of, or the PRV is operating, and please turn caps lock off
Check the AAV in the boiler.
When draining and refilling then can often develop a constant drip.
Its a water leak and please dont shout at us!
David
also check the pipe between the pump and the expansion vessel a little bit of crap in there can make it look like theres a problem with the expansion vessel
