[Advance warning - I'm not an expert so will try not to bandy around technical terms that I don't fully understand!]
Our central heating is going off occasionally for about a day at a time, and can go for weeks before it goes off again. It has gone off again now. The pressure gauge seems to fluctuating between about 0.8 and 1.2. I assume that the system just shuts off when the pressure is too low (below 1)?
A few times the boiler has been reset.
There is a screw valve below a flexible pipe leading up into the boiler (the filling valve is presume). Is it right to assume that by opening this valve, the incoming water should repressurise the system and force any air out? I don't sense that there is air in the system as there is no noise and the radiators work fine (and evenly) when the CHS is working.
The system is:
Potterton Prima F
Landis & Gyr switch
Grundfos pump
The system is:
Potterton Prima F
Landis & Gyr switch
Grundfos pump
