I have a Potterton Profole 60E boiler with a sealed system (Bolier on ground floor)
Over bank holiday the boiler failed to start when CH cycle kicked in and the pressure of the system was just above zero. I was instructed by a family friend to bleed the rads while cold whcih I did and got air out. I then re pressurised back up (via filling loop) to 1 bar and then bled again and refilled until I was getting no more air from any rads - just water.
I started heating again and bolier fired up a remained lit but pressure rose up to just over 3bar. Water leaked from the overflow pipe and the pressure reduced some but still 2.5 bar.
I left running but later in day switched off heating and watched the pressure fall back down to say 0.5bar before I switched back on again (basically I didn't want the pressure to keep falling so that I couldn't put heat back on again).
Left running overnight and checking pressure thid morning the pressure has come down to 2bar and I'm assuming it will keep falling.
I have checked for leaks and weeping valves and can't find any and all rads heat up hot (even the ones I couldn't bleed due to painted over bleed valves).
Up until this system has been running without issue for 4-5 year since we moved in.
Other info. we have a 0.5bar expansion vessel fitted. Boiler is outside in utility room but with Frost stat fitted.
Any thing else I can check for?
