Hi all
First post, so please be gentle if i'm a bit wet behind the ears.
I have just moved into a house with a Worcester 28Si II combi, which was fitted four years ago and has been regularly servced by British Gas. It appears to work fine - the hot water output is good and the radiatoras all heat up.
However, I have noticed a problem with the pressure and the manual doesn't help in the least. When I moved in, the pressure was around 1 bar when idle and 1.5 with heating on. Two days later, this had dropped to around 0.3 bar with heating on and virtually zero when idle. I followed the instructions for the filling loop and replenished the system. I have had to do this at least three times a week - seems to be more on the weekends when I use it more.
All joints and valves appear to be dry and I can't see any evidence of water leaking onto the downstairs ceilings from concealed pipes. What could be the cause of this dropin pressure? It's a bit of a worry as it just doesn't stand to reason - where's it all going?
Any advice gratfully received
