We had a Gloworm 30Cxi condensing combination boiler installed 6 years ago, with new rads and 50% new pipe work.
Ever since its always had a pressure issue, but topping it up once in a while it all that has been needed, apart from a couple of small pressure-related repair jobs.
Now, it has all gone belly up. The pressure was lost again and we couldn’t get it back. Engineer has fitted new expansion vessel and divertor vale, cleaned some other bits, but it still doesn’t work for long. The pressure drops to zero within the hour. Fill it back up, and it jumps from 0 to 0.9 immediately, goes up more, than goes down again.
Engineer said the heat exchange is dirty and the system needs a power flush with sealant. It could be air-blocks somewhere, but probably a leak – nothing is apparent though, rads all checked, no damp issues. The only place where it could be is the under the living room floor, where there is lots of pipework.
So, is it was worth ripping up the floorboards to check for leaks, or go ahead with the power flush and sealant? Have heard power flushes are a bit of a gimmick and don’t want to spend even more money on something that may not work. Any advice gratefully received, thanks.
