The heat plate (HIU or boiler) is installed in a property inside a block of flats and fed from an external commercial boiler house away from the flats.
The pressure to the heat plate (boiler) on the primary flow is 1 bar whilst on the primary return it is registering 1.7 bar?
The heating within the property is working fine, but the hot water temperatures are cold to all taps.
The system is piped up correctly, all other properties have the correct differential pressures and working fine.
All I can think of is that the heat exchanger within the plate is blocked and full of debris?
Could anyone offer a solution why the primary return is higher than the primary flow?
Many thanks
Many thanks
