Hi All,
I recently had an conversion from a vented system to closed with combi-boiler.
The shower was previously gravity-fed via a pump on hot and cold. The cold was backflowing into the hot so the plumbers fitted a reducing valve on cold supply to shower.
The reducer randomly drops to 0 BAR, cutting off the supply - I got a bit burnt in the shower. There seems to be no pattern to it. When it's supplying cold OK turning on a cold or hot tap makes no difference (I suspected incoming pressure).
If anybody could point me in the right direction it would save me quite a bit of hair!!!
Regards,
Mat.
Regards,
Mat.
