Pressure reducing valve scolding water
18 Aug 2021
Hi everyone,
I am having a problem where:
The shower powered by an oil fired boiler is:
Getting too hot after fitting a pressure reducing valve - fitted as mains water pressure was increased - making shower lukewarm
The pressure reducer is set to 3 bar and servicing a bungalow with two bathrooms with shower and two kitchens. Not much pipe run.
Does not matter how much flow is set on shower... water is scolding and boiler is set at lowest setting about 1 bar (max three)
Any ideas what could be causing this?
Reply
Report
Is this a thermostatic shower - if not, then get rid of it as it's dangerous.
The fail is most likely grit or dirt got in when the other plumbing work was done and has clogged or damaged the shower valve in some way.
Thought oil fired combis heat the water to 80C and have a thermostatic mixing valve to then reduce it 60C or so on leaving the boiler but maybe this one is working OK.
Yes thermostatic and had a new cartridge recently...
Yes they use a blender valve factory sealed and shouldn't really be tampered with.
As above I'd be looking at shower mixer cartridge and any inlet filters on shower valve first.
