I'm after a pressure reducing valve for water that has an output that will go down to around 0.1 -> 0.2 bar. Any of you guys know where I can get one from as most of them seem to bottom out at about 1.0bar.
If you told us why, we may be able to help you, if I wanted pressure that low I would feed whatever it is from a tank about 4 feet of head should do it
I would run another pipe from the loft but its a tiled boxing nightmare thats ill have to rip out to get the pipe in. Not too much hassle but if a PRV is available I'll take the path of least resistance and use that.
