Pressure relief pipe from boiler?
9 Sep 2008
I have to fit a std efficiency system boiler to a u duct and an unvented cylinder. Can i connnect the pressure relief pipe from the boiler to the plastic overflow relief pipe from the cylinder with another tundish?
Technically the boiler discharge should be separate from the unvented discharge arrangement, but yours sounds a difficult install are you sure that the plastic drain from the unvented cylinder will be able to withstand scalding hot water?? :confused:
Hi thanks for your reply boilerman. I know that it would be better seperate but I have seen this done on a Keston boiler installation and a colleague has said he has seen one too. As you say an alternative route has many problems.
