When installing a pressure relief on a ten litre undersink heater. The pressure relief is the last safety control before the unit. Is it ok to tee off the cold supply's put a vertical section of pipe 150mm in the branch of the tee then install the pressure relief valve. So the pipe from the pressure relief has enough fall to to make it to the drain?
