Pressure slowly rising in combi boiler
12 Jul 2019
I noticed a few weeks ago the pressure in our combi boiler had risen to over 2 bar. I removed about a pint of water from a radiator bleed valve and got it down to just over 1 bar.
Now 3 weeks later the pressure has risen again to over 2 bar. The heating is switched off and has been all summer. The boiler has only been used for hot water.
Its a 3 year old worcester boiler, the small plastic valve that adds water to the system is closed tight
What to do?
thank you
Has it suddenly increased after 3 weeks ,no change in between ? That would be quite odd.
Do you have a warranty ,if not you need to engage an engineer.
Thanks for the reply, it has been a slow gradual increase over 3 weeks.
It came with a 7 years warranty....just want to make sure its not something non boiler related before making a claim
You could try and isolate the cold going into the boiler to rule out a potential plate heat exchanger failure. This means you would have no hot water. Failing this, if you’re on a water meter you could do it with meter readings.
There is an isolation valve just before the boiler so it is something I could do. So if the pressure stops rising once isolated its either faulty filling valve or heat exchanger? would that be right?
If you have complied with the warranty stipulations ,then both scenarios would be covered by the warranty .
Yes that would be right and yes something you could do.
I've had the pressure rise before due to the system creating hydrogen gas. Had to hot flush with a cleaner to stop the problem
