Happy New Year People, hope you can still say that on the 12th.
I have a microbore 10mm central heating system which is about six years old. The system is a closed system with a pressured red tank, I have three two ports values.
I recently had a new central heater installed at a new location and the pipes were T'd off to install the new central heater.
For completeness, I would like to pressure test the system. My system operates at 1.5 Bar which is read on the red pressure tank.
I believe below are the correct steps, am missing anything?
Thank you.
- Start with system stone cold
- Disconnect filler loop, mains end
- Connect pressure test tank filled with water to filler loop
- Manually open zone valves
- Pump pressure pump to 2Bar
- Leave pressure for 30min and determine if it drops
Thank you.
