pressure
7 Oct 2007
Northumberland
new to plumbing need advice how do you reduce the pressure or drain the system on a potterton puma 80 system need to take the pipes off one rad for repair.
:( :cry: :?:
outlet pipe blocked 10mm micro pipe could be blocked from manifold in attic can.nt get hold of a 10mm isolator valve to put in the attic to work on the pipe.
:confused:
Plenty of 10 mm compression lever valves available!
You could turn off the isolating valves under the boiler and potentially keep the hot water facility. But they have a tendancy to leak afterwards.
Tony
