Pressure?
21 Mar 2006
London
Old (upstairs) radiator was leaking, so I switched it off and left it for a while because I was going away.
Went away, switched the central heating off. Came back, central heating not working. Not firing up.
Bled the radiators. Downstairs - no problem. Upstairs there is a gush of air but no water (is the air gushing in or out?) After bleeding (I think) the central will fire up - but it does not last.
I have now removed the old radiator and capped off the TRV end which was dripping a bit.
Any idea what is going on with the Central heating, is it to do with water pressure or air in the system, and does it make any difference to how I should proceed?
Hi Jamie,
Sorry to be a dunce but I don't know. I've got 6 radiators in a three bedroom house. A back boiler (Baxi Bermuda) and a hot water tank and a cold water tank in the loft. Does that help?
check the small tank in the loft for water . has it got any ?
Hi Jamie,
I checked and there's very little - an inch. So the ballcock is hanging in the air above it.
Despite this the central heating did come on last night. But something is obvuiously wrong what should I do now.
