vokera linea models have a lot of different reasons for pressure problems, so i will do my best to describe a couple of things you can check.
1. Top the pressure up to 1 bar exactly, that way your eye wont fool you, if you are persistently checking the pressure to see for signs of movement. Leave the boiler off if possible for maybe 2 or 3 hours, then check the gauge has it dropped at all if so, how much? and how long did it take?, if this is the case you may have a leak on the system pipework, boiler or more commonly its safety valve. (Keep note of your first tests results).
2. Now turn on the central heating, and adjust the central heating thermostat to full. The boiler will eventually cut off due to reaching temperature, depending on how many radiators you have will depend on how long it takes to cut off. During the time the boiler is on you have to monitor the pressure gauge to see now how much it rises, this will tell me if their is a boiler related issue, and if so you need a competent gas safe registered engineer to fix it.
Hope this information has helped.
