We have a private, rural water supply which consists of a well pump feeding into a 50 gallon tank in the (not very high) loft. This tank then gravity feeds the cold water taps and hot water cylinder. The pressure is terrible.
I'm doing a bit of renovating and want to pressurise the system. My plan is to relocate the storage tank (as the loft is being converted) and have it directly feed a pressure booster pump which will then supply the house including the hot water tank. Questions.
1. Does the general idea/approach sound reasonable?
2. I've had a look at available pressure sets and thought the combined stainless steel pump and pressure exp vessel from Draper/Clarke looked good value. About £160 for a 55 ltr/min, 24ltr expansion tank. 800 watt motor. Does this sound sufficient for domestic usage? Any other pumps better?
3. Our hot water is a dual cylinder indirect type (2 years old) and there is an air-trap vent on the incomming pipe (perhaps outgoing?). Is there any issue with pressurising this type of cylinder?
4. Any other hints or suggestions would be very welcome.
Thanks in advance.
Sparky Joe.
Thanks in advance.
Sparky Joe.
