I have a 600mm by 300mm porcelain tile that I have cut with a Plasplug electric tile cutter. It is the diamond wet wheel contract plus model.
I had to buy a special disc to cut porcelain but it still left chips along the tile after cutting the bit I wanted off.
I did it slowly and as straight as I could using the guide.
It is a good job that this tile was being fitted at the top of the wall of my bathroom where the chipped end will come in contact with the ceiling.
Can somebody please advise a solution to this problem? Thanks.
