I am completely relaying out my bathroom, ie gutting and moving all fittings to different locations. Many of the waste runs have to go under the tiled floor, so I will be using solvent weld wherever possible.
I have three alternatives for my shower waste.
1) To run it into an old push-fit boss on the soil stack within the floor/ceiling void. The old boss looks OK, but the seal is old and not replaceable and I’m worried it may leak.
2) To tee it into a new 4 metre run of 50mm pipe going from the bath to the stack, teeing in approx 1 metre from the stack. The downside of this is obviously the possibility of siphoning the shower trap when emptying the bath. As far as I can see there is no feasible location for an AAV, due to the need to keep it high and accessible.
3) To tee it into the 50mm run from the bath as in option 2 above, and then run a vent pipe from the shower branch to the old pushfit boss in option 1, thereby venting the shower branch to the stack.
Would option 3 be enough to stop the shower trap siphoning, and would it be considered good practice. The old pushfit boss (vent) would be approx 200mm above the new 50mm boss.
I have pics and a sketch if they would help.
Thanks in advance for any help or advice.
