I posted about a week ago for a problem with my boiler. I now have more info and hopefully someone can help me out.
The boiler is a potterton Prima 40F - The fan comes on only for a few seconds and then you hear a tick and it goes off. It then comes back on in a cycle and maybe after 10 or so minutes it ignites.
I've had an engineer out who has checked the fan, the air tubes and has changed the air pressure switch and this has not fixed the problem. He suspects it could be the PCB but Potterton have said they don't think it's the PCB and is probably a corroded flue.
It doesn't seem like the fan is on long enough to create a vacuum and activate the pressure switch. Once it sparks it ignites fine and runs until things are upto temperature.
How can I check the flue and what would I be looking for i.e. holes? Any advice or toher suggestions appreciated.
