Hi, I've just installed a Prima Cooker Hood, but I'm not convinced it is setup correctly and would appreciate a second/third opinion to confirm this.
It's a simple cooking extraction unit comprising of a hood with a fan, light and switches and a decorative telescopic flue, all in stainless steel.
This is replacing a similar Hygena hood, which is no longer available, so I've installed the new Prima hood in a similar way.
The original hood was NOT ducted in any way. It also didn't have any carbon filters fitted, so essentially only the washable filters on the lower face of the hood were being used and the air would have been pushed up the flue and out through some flue vents in the stainless steel flue just below the ceiling. The new Prima hood is the same, or so I thought.
This time, I have purchased some carbon filters. The instructions suggest (they aren't very clear) that when the carbon filters are used, it is necessary to fit some flexible ducting from the top of the hood to the top of the flue. As this flexible ducting isn't supplied, I'm at a loss as to what difference it would actually make as surely the air will still be directed up the flue and out of the vents at the top of the flue? Why would the ducting be required when the carbon filters are fitted, but not required when they aren't?
I've attached a manual, which uses pictures to show the various installation steps and English instructions on page 15. It isn't very well written. Tried to contact Prima Customer Support but they don't exist and the number I did get through to suggested I spoke to the suppliers of the product, as if they would know the intricacies of installing every product they sell!
