Prima LPR600
22 Dec 2006
Warwickshire
I have a pressure problem, because the flat pipe coming from the bottom spray are keeps popping out of it's hole in the spray arm mount, i have removed the parts and found that the clips that hold the pipes securely down are broken, allowing the pipes to quite freely pop in and out. Can anyone help me locate a new bottom spray arm mount, as i have looked everywhere, it is the part that is held down with the 4 screws. Thanks :oops: :(
Whirlpool machine. Local shop should be able to obtain the part for you.
