- Joined
- 17 Feb 2006
- Messages
- 375
- Reaction score
- 2
- Country
After fitting of landing carpet the bathroom door is catching on the door plate.
I've taken it off, and planed a bit off the bottom.
Before I re-hang it I thought I'd (at least) prime the bottom edge.
Questions:
1. Do I need to paint it at all? It's the bottom edge, the top is already painted. Not sure if it will absorb a lot of moisture. And at least one internet suggestion is that leaving it unpainted allows moisture to get out as well as get in.
2. If I do need to paint it is oil based primer enough to seal it? Given how long gloss takes to dry I don't want to leave it off too long.
3. There will actually be a fairly big gap under it, at least in the bathroom. Any tips for painting it in situ? Pads or something similar?
Questions:
