Priming Lime plaster (L&P wall)
24 Feb 2013
Berkshire
Im planning to tile my bathroom and I'm thinking i should do something to help the lime plaster not crumble before tiling. Is Mapai Primer G suitable for Lime plaster walls? I like the belt and braces approach so dont mind if it's a bit of an overkill.
http://www.pureadhesion.co.uk/mapei...1-litre.html?gclid=CMrm4Yqm87UCFUvHtAodWGIAoA
Also what adhesive would you recommend for tiling 300x600, 8mm tiles (21kg/m) in a shower area, i plan to use cement based
Simon
The answer is to not put tiles over old lath & plaster walls at all.
Remove the lot and reboard all of the walls.
