- Joined
- 27 Jan 2008
- Messages
- 24,925
- Reaction score
- 2,882
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
In the main I print at home but I have printed odd few in college and the printer is far better than mine so I have considered printing some of best in Asda or similar but not sure of format required to print.
All my photos are take in RAW format and when I view them as second file is created which contains the view information. As 16 bit this is of course far better than Jpeg and would seem the best format. However not sure if the print houses can read this?
When I use HDR I normally start off with 32bit Tiff files these are then through tone mapping reduced to 16bit Tiff files I often then load the tiff as a camera RAW file and again do final adjustments which then also produces a second file that stores the adjustment information.
Printing from home or college always the picture is loaded into Photoshop to print so does not really matter if 8, 16, or 32 bit Photoshop will still handle it.
I guess I could save in near any format but I know normally to get something printed one uses "Post Script" but other than knowing it exists and is something like PDF I have never used it.
So wonder what is the normal format to get work printed? Also what sort of range the printers will handle. At home limited to about 6EV stops and at college maybe a little more around 7 to 8 EV stops but many start out at up to 12 EV stops and I wonder how much they need compacting before printing?
