PRO COMBI BOILER NO HEAT OR WATER NOT FIRING
17 Dec 2010
Hull
I have a Procombi boiler and today the green light has been flashing intermittently every 0.5 seconds (but working fine). Now however, it is flashing intermittently green and doesn't fire up. Neither heating nor hot water working. Any ideas what the problem could be?
There are two dials. One showing at 10 and the other at 2. The green light is now red
get it seviced the venturi will be full of carp. have one that needs doing every year without fail
are there any fault codes showing up on the display? when you open a hot tap does the boiler start and then stop? any noises?
