This will probably sound like a silly question but here goes.
I was having problems with my gas heating ( combi boiler with 2 zone controls managing the hot water and central heating)
Anyway in my investigation I removed the 2 port motorised actuator and manually turned the valve spindle. The spindle had no stop positions as like a gas valve (eg only 90 degrees movement). I can't remember if I returned it back to the original position or if i've turned it thru 180 degrees from original position.
My question is - I assume the valve is like a ball valve so long as the spindle mates OK with the valve actuator, everything is OK?
Or if the spindle is 180 degrees out does it cause any problems?
Thanks in anticipation.
