Sorry - This is a B.O.G.O.F question
1. Need a new combi/consensing boiler in the kitchen of a house I've just bought. Existing one is on its last legs and in totally the wrong place. Have found a Worcester Bosch Greenstar boiler which could be wall mounted in the kitchen between 2 wall units. It is on a frame so there is no exposed pipework. In the pictures looks very neat. But what about the pipes which actually supply the boiler? Whether they feed the boiler from below or above, surely they will be exposed and therfore would have to be boxed in or concealed somehow? Can pipes for boilers be chased into the wall, buried in plaster using conduits and brought to the surface behind the boiler as required?
2. What about pipework serving the radiators in a house where ground floor is concrete rather than floorboards? At the moment just about every downstairs room has pipes running up and down the surface of the walls. Can these be chased into plaster and hidden or is the only solution boxing in?
