Problem: Circulating pump failed - new pump fitted - now the boiler seems to randomly fire up regardless of requests for heat. i.e. can turn controls to "Off" but boiler keeps firing.
I have an elderly but usually reliable heating system. It has evolved over the years and now consists of: Ideal Mexico Super 2 CF-60, new circulating pump just fitted, ST699 that only controls hot water, CM61 for the CH, V4043 motorised zone valve, copper hot water cylinder in the airing cupboard with L641A stat, F & E tank in the loft.
The pump was replaced because I came home to find nothing working. The 3amp fuse in the spur had blown. Diagnosed the old pump was U/S. Went to close isolator valves and they leaked. So, drained system, replaced pump plus new isolators. Connected up, turned on and everything immediated sprang to life. Job done or so I thought.
Any help / advice greatly appreciated.
