- Joined
- 1 Sep 2009
- Messages
- 96
- Reaction score
- 2
- Country
Hi and I really need some advice on this ASAP..
I had the end blow off the water valve in my cistern which would have flooded the place if I wasn't in.
I've purchased a replacement valve complete with the arm and new washer etc
When it arrived I could see that the thread end was much longer than the one I took off.
This is the bit that goes through from inside bottom of cistern to attach to water inlet.
I called the supplier and he said I would have to shorten the end if I couldn't move the pipe down. The pipe does a right turn through a wall so it can't be moved more that maybe 2mm at most up or down.
I cut the end to match the length of the old thread but it was still too long and up tight against the end of the inlet pipe olive! I couldn't tighten the plastic nut fully so the conical washer wouldn't seal, so I took off a bit more so all looked good.
Tightened up plastic nut and conical washer nice and tight (not too much)
BUT........ The metal nut will not tighten onto the plastic thread (I've really tried for over an hour)
Note. The inside diameter of the new valve pipe thread at the bottom looks about 1mm smaller! (is this the problem, it will not move down)?
And because I've had to cut the plastic thread down to size I think I'm stuck as the beginning of the pipe looks like it had before I cut it a very slightly bigger diameter.
This too is the same for the one I took off, but the old pipe is way shorter and still has the slightly bigger diameter for about 10mm inside the plastic pipe!
Should the top of the metal nut on the water inlet slide or tighten etc above the top of the olive?
(it seems to stop and not want to up any further!)
It seems to me because the old valve/pipe could move down on the olive by a few mm which was below the top of the olive the metal nut could catch the end of the plastic thread!
But the new plastic valve pipe thread will only sit on top/level with the pipe!!!
Old and new parts are made by Fordham with the curved arm to go around the syphon.
Any advice very welcome as I have no way of isolating the water to the toilet so this is a big problem now, no loo, sink or shower
Thank you..
Thank you..
