Right brought myself a bung kit, bunged the header tank and opened a vent to create a lock in the system to replace some valves on a downstairs rad (1 by 1 obviously). Problem is I got about a pint of water from the vent and got a little worried that was too much so closed it again. I opened the vents on the upstairs rads 1 by 1 and all of them had some air in but no water and eventually no air, checked the tank and definately bunged right.
So went back to the vent and reopened to be greeted with another pint of water I should I have just kept going or is this not right? The drain valve is on the return under the rad that I want to change the valves on but its so old am worried it might break and not reclose and I've not got a hose?
Sorry for waffle but got it right in my head then nearly 2 pints of water came out of the vent with no signs of stopping, should I just have kept going till it stopped or is there another problem?
